Dont know if its
already a problem with the gate.
But after the latest upate with the new editor,
i have this background noise again.
http://www.filedropper.com/moog
here you can hear a little example.
Would be nice if someone can help me
New Background noise
Re: New Background noise
I had something similar after updating. Rebooted, changed cables, the noise stopped. Not sure if it's related.. I assumed it was a cable that coincidentally went bad, however that didn't explain how it was affected by the filter. Does it go away as you lower the cutoff?
Dont know what went wrong.
Moog told me to send the unit in for support.
Dont know if i have too.
I loaded up an other sound file.
Would be nice if someone can check it.
Sometimes it seems gone.
Load preset Nr. 4 from the new editor called BottomBarrelBass.
Can someone tell me please if only on my unit are these artefacts after the sound release.
http://www.uploadserver.net/s/download/ ... 51592/Moog Minitaur Sound.mp3
Sorry i made a mistake.
The preset where you can heare these artefacts is
Preset 5 Brighter Fifth.
Not 4
Some answer would be nice
Not 4
Try plugging the PSU into another outlet. Also, try using it without USB, via MIDI only. Does the noise go away?
http://audiotecna.info
Tried everything.
Got a new unit by my friendly music dealer to compare it with my one.
The new unit works great without this sound artefacts.
So my unit goes to repair.
