Minitaur new background noise since update amos
Posted: Thu Nov 07, 2013 5:38 pm
by absentmusic1
can someone tell me what the newest problem is ?
I attached a soundfile of my minitaur.
After some firmw. update i have this noise in my notes.
Dont know when it started.
But its not up to firmwire 2.8
But with 2.16-21 i have this noise.
You can hear it best when the note is ending.
This kind of scratching noise in the backround of the note.
Any help ?
http://www.megafileupload.com/en/file/4 ... d-mp3.html
Sorry dont know how i can submit the file on an better way.
Hope someone listen to it.
Re: Minitaur new background noise since update amos
Posted: Fri Nov 08, 2013 1:33 pm
by Amos
i heard this noise in earlier versions but on my Minitaur I don't hear it now.
Try this firmware and tell me if the noise is the same:
http://www.moogconnect.net/downloads/mi ... 2_0_22.syx
if it is, next try turning down the Ext. Input level on your Minitaur (using the editor, or midi CC# 27) and see if the noise goes away. Let me know in either case.
Posted: Fri Nov 08, 2013 4:35 pm
by absentmusic1
Thank you for your fast reply.
Im sorry the update doesnt change the problem.
Ext Audio is down.
Posted: Fri Nov 08, 2013 6:42 pm
by Amos
Posted: Sat Nov 09, 2013 2:33 am
by absentmusic1
Sounds good with the .23 update
The noise seems to be gone.
Not 100% sure if its 100 % gone.
But much better.
And i think its OK
Thank you for midnight exchange
Posted: Fri May 22, 2015 4:07 am
by bellay
Old topic, but I too have this problem... My Minitaur is on firmware version 2.1.1. The noise starts to be audible after note starts to fade away, it goes around 5khz. Also, when I turn off usb cable the noise is little bit quieter but still there. On first firmware I had there was no noise at all. Other forum member posted soundcloud link with sample, it basically sounds the same
https://soundcloud.com/cyklops/moog-mt- ... -a/s-fc0u9
Any suggestions? Thanks!
Posted: Sat May 30, 2015 4:35 pm
by bgirl
I have the same exact noise on my minitaur also, latest firmware. It varies in speed with the amp decay knob.
Please Amos !
