Hello there,
it's a newbie question
Is it possible to plug an expression pedal in the minitaur to control the filter cutoff frequency ?
If so, which one you guys use?
Kind Regards
Expression Pedal to drive the filter cutoff
- Portamental
Re: Expression Pedal to drive the filter cutoff
Yes it is. I like the M-Audio EX.P. It's cheap, very well match to Moog gear with a 50k pot, an external trimmer and a switch for even more trim control. It is smooth to operate and you can control pedal stiffness easily.
ya, I use Moogs expression pedal 2, works well on pitch, filter, sustain inputs...
Thanks for that, I will into those pedals.
Cheers
Cheers
