http://www.moogconnect.net/downloads/mi ... 2_0_28.syx
now we are getting somewhere!
Fixed in this version:
- Good old tuning (you will need to do Note Calibration if updating from 2.0.25/.26, but probably not if updating from v2.0.21)
- fixed Knob Mode behavior; Relative knob mode should work consistently now.
- new panel knob function: Hold GLIDE + turn FILTER ATTACK knob to select TRIGGER MODE (legato on, legato off, reset).
- fixed Save Preset behavior... see below
To save a preset in place, it's the "older" way again (although a little faster)... first press GLIDE, then while holding GLIDE press RELEASE; hold for half a second, done. The GLIDE and RELEASE button lights start to pulsate, then they go back to normal and the MIDI LED blinks to confirm preset is saved.
To save a preset to a different location, it's simplified similar to your suggestions... Press GLIDE + RELEASE and then let go, instead of holding for half a second. You'll see the GLIDE and RELEASE button lights pulsating... while it's in this mode, you can scroll up/down through the presets by pressing the OSC 1 and OSC 2 waveform buttons. When you get to a preset you want to save over, press GLIDE + RELEASE again to finish saving. If you want to exit this mode without saving, press the RELEASE button by itself.
To output all parameter values as MIDI CCs, this is the same as before: while holding the GLIDE button, double-tap the RELEASE button. This only sends MIDI CCs and does not save the preset to internal memory.
A note about saving presets "in place" -- the Minitaur always boots to Preset 0 and preset 0 always gets the real knob positions from the panel, instead of using the saved values for the panel knobs... so if you turn on the Minitaur and tweak up an amazing sound, you might want to save it to a different location rather than saving it to Preset 0, because your saved sound won't always sound the same in that particular location. You may have already discovered this.
I added a global setting for this (preset 0 behaves like all other presets, or preset 0 always gets the panel settings)...
here are a couple sysex "commands" for turning this on and off. "preset 0 is static" is the new setting where preset 0 acts like any other preset. "preset 0 is dynamic" is the default behavior, where the MInitaur uses the real knob positions any time you switch to Preset 0. (the Minitaur always loads preset 0 when you first power it on)
http://www.moogconnect.net/downloads/mi ... static.syx
http://www.moogconnect.net/downloads/mi ... ynamic.syx
