Fixed! Added a physical shortcut for panic/all-notes-off.
http://www.moogconnect.net/downloads/mi ... 2_0_14.syx
New in v2.0.14:
- still more improvements to Release/Decay control behavior.
- Resets globals to default on update. I hope this prevents some of the weird problems that affect only some users and not others.
Default global settings are:
Knob Mode = Relative
Note Priority = Last Note
MIDI In/Out channel: 1
MIDI input transpose: none
MIDI CC filter: off
14-bit MIDI: off
Load Preset Volume: off
Load Preset Mod Wheel: off
- Panel shortcut for "all notes off" : Press & Hold the GLIDE switch, then (while holding GLIDE) turn Amplifier SUSTAIN knob to zero.
- Bonus: Panel shortcut for "Gate always on" : Press & Hold the GLIDE switch, then turn Amplifier SUSTAIN knob from zero to maximum (turn the knob to zero and then to max, all while holding in the GLIDE switch). Use the "all notes off" shortcut to turn the gate off again when finished (droning/filtering/etc...).
Enjoy,
Amos
ALB wrote:...while i'm writing, the minitaur freezed on a release/note on.
What controller are you using to send notes to the minitaur? just curious if this is maybe a factor...
