upgraded from version Minitaur_firmware_v2_0_30.syx to Minitaur_firmware_v2_0_32.syx
EDIT: updated this post to reflect problems still in v2.1 and an extra error i found.
here are my thoughts
MANUAL NEEDS TO BE UPDATED FOR GLIDE TYPE
0-42 LCR
43-85 LCT
86-127 EXP
LFO MIDI SYNC (PROBLEM 1) (Shows in MIDI Data as: Controller 87)
does something strange
if you send it a value of 64, it changes to 65
the manual shows 0-63 / 64-127 so shouldn’t it default the the first value of the parameter range (64)?
LFO MIDI SYNC (PROBLEM 2) (Shows in MIDI Data as: Controller 87)
when i set midi sync to ON (64 that becomes 65) the LFO speed DOES NOT change to the speed of the interval i have selected.
its as if the clock divider is having no effect on the LFO.
i cant get the LFO to sync to tempo in ableton or pro tools.
LFO CLOCK DIVIDER VALUES
FIXED!
LEGATO VALUE INCORRECT (Shows in MIDI Data as: General Purpose
if you send it a value of 64, it changes to 2
KEY TRIGGER VALUE (Shows in MIDI Data as: General Purpose 7)
thats all I’ve got for now. out of time.
thx for your effort amos
cheers
