I've searched this subject but have not found a suitable answer.
My T3's don't leave my studio and am curious if they need "tuning" from time-to-time.
I wouldn't think an electronic insturment (analog or digital) would drift like a stringed insturment. Do they?
If so, is there a patch of some sort that will accomplish this?
Thank you.
Do T3's Need Occasional Tuning?
Rael Imperial Aerosol Kid
Re: Do T3's Need Occasional Tuning?
I have found the T3 very stable, but yes analogue gear can drift , some synths are notorious for it.
It can't harm to tune them occasionally. Check the Calibration section of the manual on how to do this.
- stiiiiiiive
Digital won't drift, FYI.
I just recently updated the firmware on my T3. After which you are supposed to run the calibration utility.
I was surprised that the oscs had drifted out. They did not sound out to me. Though I swear after the tune-up the T3 sounded more centered and solid on those notes.
Taurus III, Digitone, Dark Energy, OB6, MG1, Grandmother, Blofeld
As you can tell from the built in calibration routine, there might be a need to tune the oscillators from time to time. But due to the automatic process and the trimmer free built oscillators, this is a easy thing to do. There are a few additionally trimmers found on the analog side of the PCB that might need some calibrating in years to come. As Moog is not releasing service instructions to the public, you need an Moog authorised technician for these. But I guess, we don't have to care about this now.
Sequence:
Sequence:
Tuning drifts I would assume are gradual over time. How can I tell if mine is not as it was when it left the factory?
The manual on p. 46 Note: 6 states "Note Calibration is not meant for overall tuning drifts,....".
I can tell if my guitar is out of tune just by strumming an open chord. Not so simple with bass pedals. What method do you use for a test?
When i upgraded my firmware a few months ago, i used the calibration feature and it worked nicely. Its been solid in tune since then.
MF102, MF104M, CP251, Minitaur
I suppose you could use a guitar tuner to check. But honestly, when I ran the calibration procedure none of the oscs were more than a few cents out. That is not something that you can see on most cheap tuners. A petersen Strobe style tuner would be needed. Or a killer ear.
