http://www.moogmusic.com/news/minitaur-revolution-2
I haven't used MIDI much, so I don't know how to send a program change from my Alesis Micron (which is what I'm using to control the Minitaur). I made the preset in the Minitaur Editing program along with under the hood settings. I was able to scroll between the two presets that I had made and loaded. The 200% filter tracking doesn't work. Bummer.Amos wrote:have you tried MIDI program change? It works fine.
edit: as long as you are changing to a program that is valid - meaning you must load a preset from the editor to the Minitaur's internal memory first... after that, you can send a MIDI program change and it will load the preset.
yes, the midi program change works perfectAmos wrote:have you tried MIDI program change? It works fine.
