T1's Lamps don't really do
krohurte
Post by krohurte » Tue Dec 06, 2011 5:26 pm
hello
The red on/off lamps indicating glide and decay don't do anymore. They're always off. So any tips how to fix this? Minor procedure or should I let someone do it since I have absolutely no idea about the innards of the mighty T? I'm a musician, not a doctor. I've never opened the thing before.
Mr Arkadin
Re: T1's Lamps don't really do
Post by Mr Arkadin » Tue Dec 06, 2011 6:02 pm
Before opening it up try reflashing the firmware. To be honest I doubt the LEDs are controlled by the firmware, but you never know and it's free to try.
http://soundcloud.com/luke-antony
krohurte
Post by krohurte » Wed Dec 07, 2011 6:40 am
hm I don't think it's a firmware issue with the Taurus 1... :)
krohurte
Post by krohurte » Wed Dec 07, 2011 6:47 am
oh one more thing (no need to open yet another topic): like on this pic:
my pedals have the same icky rubbery gluey frame thing there. What could this have been? I thought mine's previous owner has attached something weird to it and obviously he wasn't the only one. So what's the best (= harmless to the material) cleaning procedure here?
Mr Arkadin
Post by Mr Arkadin » Wed Dec 07, 2011 7:52 pm
krohurte wrote:hm I don't think it's a firmware issue with the Taurus 1... :)
:lol: That's what I get for answering just after I wake up. I forget there are other Taurus models before 3.
superd2112
Post by superd2112 » Wed Dec 07, 2011 10:25 pm
Sounds like the indicator LEDs are burned out. A fairly simple procedure to replace them (if you're handy with a soldering iron), and the sticky stuff is the glue for the panel transparancy starting to decompose & ooze out. This ooze can be rermoved with elbow grease, a terry cloth towel & some rubbing alcohol.
The bad news is that not long after the front transparancy starts oozing, it is common for the foam material used as dust barrier & applied throughout the interior to start decomposing too. It sounds like this is already happening to yours. When this happens, it's not just a mess, it is a major clean-up job best left to professionals.
a2dconverter
Post by a2dconverter » Thu Dec 08, 2011 8:56 am
Hello krohurte
For removing label glue, I have found that Citrus based cleaners work better than alcohol... Here in Canada we have a product called Goo-Gone that safely removes stickers. (Do not confuse Goo-Gone with a product called Goof-Off which contains Xylene and will remove paint!)
The LED's are most likely not burned out... but, the circuitry driving them has failed... It must be a common failure as a couple of the LED's are out.... It's most likely be a cold solder joint on a common power line feeding the Logic IC's.
If you are technically inclined (and safety oriented), you can check for +5 VDC using a voltmeter between PIN 14 and Ground on IC908 and IC910 to see if those IC's are receiving power. If not, re-flow the solder joints on the ground and power lines feeding those IC's and the actual power pins on the IC's (PIN 7 and 14). Also check component leads near those IC's that transfer power from one side of the PCB to the other . (been there, done that for the exact same problem!)
http://whyleuwait.com/T3/T1_Story_March_2010.pdf
Schematic here...
http://www.synthfool.com/docs/Moog/taurus1/Moog_Taurus_Schematic.jpg
I hope this helps
Regards
Joe
_____________________________________
Moog Taurus I #1708 (1972)
http://stagecue.com/t1.html
Moog Taurus I (1981) Custom Table-Top x MIDI IN
http://stagecue.com/t3.html
Moog Rogue #2040 (1981) x MIDI IN x internal PS
http://stagecue.com/rogue.html
krohurte
Post by krohurte » Sun Dec 11, 2011 7:00 am
thanks guys for all the info. yes, it's obviously better to take it to a professional. :)
Baker69
Post by Baker69 » Wed Dec 21, 2011 3:55 am
Hi there,
I remember replacing an LED on one of the buttons on my T1 and it was a fairly straightforward procedure. The fact that all of your LED's have gone though seems to indicate something a bit more serious. What I would do initially is open the case and check all of the connectors to make sure one of them hasn't come loose.
Cheers.
krohurte
Post by krohurte » Fri Feb 03, 2012 3:42 pm
ah no it was only 2 lamps that didn't work right. Glide and Decay. Funnily enough they've been working for a few weeks now after I had a repair guy checking them for a service fee estimate. I then didn't have it repaired (for 300$ all the lamps have to blow up first) but maybe simply by opening the chassis the lamps might have gone back into a working state again... :lol:
Voltor07
Post by Voltor07 » Fri Feb 03, 2012 7:59 pm
krohurte wrote:ah no it was only 2 lamps that didn't work right. Glide and Decay. Funnily enough they've been working for a few weeks now after I had a repair guy checking them for a service fee estimate. I then didn't have it repaired (for 300$ all the lamps have to blow up first) but maybe simply by opening the chassis the lamps might have gone back into a working state again... :lol:
Sounds like an intermittent connection/bad solder problem. Unfortunately, $300 is pretty reasonable for a tech to fix whatever is wrong with the Taurus...especially when replacement parts are involved. :wink:
Sub 37 #000068, Minitaur, CP-251, MF-102&103, EHX #1 Echo, EHX Space Drums/Crash Pads, QSC GX-3, Miracle Pianos, Walking Stick ribbon controller, Synthutron.com, Lowrey Teenie Genie.
