Moog Music Forum
Share Ideas and Pass the word
EP-3 Expression Pedal with EHX Pitchfork Problems
This is the place to share tips, tricks and questions about Moog's controller products; the MP-201 Multi-Pedal and the EP-2. There are a world of applications for these expression enhancers. Explore...
Postby bachrock » Thu Sep 14, 2017 8:17 pm
So I have an EP-3 Expression Pedal hooked into an EHX Pitchfork. The pedal used to work, but now only intermittently works. Has this happened to anyone? Might this be something I can fix by taking the pedal apart?
bachrock
Re: EP-3 Expression Pedal with EHX Pitchfork Problems
Postby SlowLFOtoPitch » Fri Sep 15, 2017 11:08 am
Hi Bachrock,
It sounds likely that it is the TRS cable, as the EP-3 is quite sturdy. My suggestion would be to try another TRS if you have one, 9 times out of 10 the cable is the problem.
TAYLOR MOTT
SERVICE DEPARTMENT MANAGER
MOOG MUSIC INC.
P: (828) 251.0090 ext. (217)
Fax: (828) 254.6233
SlowLFOtoPitch
Return to Controllers Forum
Who is online
