sequencing model d with mp201
This is the place to share tips, tricks and questions about Moog's controller products; the MP-201 Multi-Pedal and the EP-2. There are a world of applications for these expression enhancers. Explore...
Unfiltered
Post by Unfiltered » Wed May 11, 2011 7:26 pm
is it possible to use Logic to sequence a model d using the mp201?
c7sus
Re: sequencing model d with mp201
Post by c7sus » Sat May 14, 2011 4:33 pm
It should be able to handle that.
You could probably modify preset #27 to take the incoming MIDI messages from Logic and output the corresponding CV's.
Playing a Model D using Logic or Sonar through an MP-201 would be a really great demo of the power of the 201.
Unfiltered
Post by Unfiltered » Sun May 15, 2011 8:55 pm
thanks for the reply. I seem to have trouble getting a s-trig to function correctly. What settings do I need to adjust to get the gate out to s-trig to function correctly?
c7sus
Post by c7sus » Sun May 15, 2011 11:41 pm
Maybe this will help.
http://www.synthesizers.com/gates.html
http://www.synthesizers.com/moog_trigger-convert.jpg
Apparently synth.com sells a cable for this purpose too.
http://www.synthesizers.com/cables.html Scroll to the bottom to see the cable. You might try contacting synth.com for verification this solution works for the Model D.
Indeed
Post by Indeed » Sat Oct 29, 2011 9:50 pm
So what's up? What happened here? I'm wondering if I could do this too!
MPC3000, MF-101, 102, 103, 104Z, 105M, 108m, 107, CP-251, MINI MODEL D, OB-8, ALESIS A6, ARP ODYSSEY MK1, RHODES MK1
Indeed
Post by Indeed » Tue Nov 01, 2011 8:16 pm
I've been researching is all over the web, & I'm gathering that this is not possible because an s-trig needs a higher voltage to open the envelope of the model d, and the mp201 is not equipped for this.
Am I correct in this? Amos? Anyone in the know here?
There are devices that ARE equipped for is like the doepfer mcv4, Kenton pro-solo, etc. I was hoping to sort of get 2 birds with 1 stone on this.....while I'm spending the money, why not get a piece that can work with the model d as well as the cv's of my foogers, minimoog & other synths.......
Sir Nose
Post by Sir Nose » Thu Nov 03, 2011 12:57 am
If the voltage is not high enough, boost it.
