MP-201 Foot pedal calibration
Pantherairsoft
Post by Pantherairsoft » Fri Jan 28, 2011 1:20 pm
Can any MP-201 users offer some wisdom…?
I'm not sure the foot pedal on my unit is functioning to its full potential. For example with my MF-101, with the cutoff set to 250 and the footpedal heel position at 0, I would expect that the toe position of 4095 should be enough to act as though I'd turned the cutoff control up to max… however it only sounds as though i've turned the cutoff up about 75%. That seems a very short sweep for an expression pedal. In fact my EP-2 allows a further sweep.
Also, when selecting heel and toe positions for a setting, I enter edit mode as always, select heel, move the pedal forwards to the desired start point and save it. then after exiting edit mode, I pull the pedal back to heel position (which should now be set to the value of the pedals last location) and the sound moves lower than the value I just selected. Surely the first time you pull the footpedal back from where you set the heel value to it should not change at all?
Sorry if this is rambling!
When I go to footpedal calibration in the utilities mode and rock the pedal back and forth it displays the heel value as 385 and the toe value as 3880 (rather than 0 − 4095), doe this mean that anything above and below those values has no effect? If so, how do you calibrate the footpedal to run the full 0 to 4095?
Any help is much appreciated...
Shep
Shep on Bass - My website & blog
Bitnormal Records - Netlabel specialising in electronica
KADE - Improvised live electronica
Patient Zero - International hip-hop & electronica collaboration
Pantherairsoft
Re: MP-201 Foot pedal calibration
Post by Pantherairsoft » Sat Jan 29, 2011 12:54 pm
Issue with the sweep resolved by switching to Bi-Polar mode!
Other issues still a mystery to me
Pantherairsoft
Post by Pantherairsoft » Wed Feb 09, 2011 4:12 am
No one?
SteveD
Post by SteveD » Thu Feb 10, 2011 9:52 am
Hello Shep -
The MF-101 Filter Cutoff input is set so that it only sweeps ~50% as much as the knob. Originally when we designed it - we thought a lot of guitar players would be using it and the musical bandwidth of the typical guitar signal is less than the full sweep of the VCF. so we limited the expression input so that it could be used more like a typical "Wah" sweep. So what you experienced is normal, and you found a workaround - feed the Cutoff control w/ a bi-polar CV (+/-). In general on current Moog gear (except for the MF104, MF105) frequency related control inputs do respond to negative CVs fairly well.
As far as viewing the pedal range in the calibration mode - a less than full sweep is perfectly normal - and that's what calibration is for - it maps the existing sweep to the full range.
As far as the editing the heel value - I confirmed that can happen on a unit here - but it stopped doing that when I calibrated the footpedal. Make sure when you calibrate the footpedal that you're not smashing it down in the heel or toe position or you'll never be able to get the full range. If you have display units set to "precision" you can verify the real range of your pedal.
Hope this helps!
SD
Pantherairsoft
Post by Pantherairsoft » Thu Feb 10, 2011 4:45 pm
Great stuff. The work around is perfect and as for not seeing a full range in calibration mode makes sense. Still struggling with the heel though.
If I edit a patch, allow the heel value robbed altered, move the pedal to where I want the heel to be, in this case the read out says it's at 750, click the scroll wheel so the heel still says 750 and save the preset. At this point the pedal is slightly forward (as it was moved to the position of 750 in order to save that value to heel... So in theory if I rock it back to the actual heel position the tempo should not change... But it does, it drops way below the 750 threshold I set.
If I go back into the edit mode, the heel still claims it's 750, edit the patch and move the pedal forwards to 750 again and I get the tempo I had thought was 750.
Seems the footpedal is not actually reading the heel setting when you come out of editing it.
I'm a bit lost....
Shep
Rabalder
Post by Rabalder » Sun Oct 09, 2011 12:19 am
Any news on the calibration issue?
Mine is stuck at 300 and 3900.
Pantherairsoft
Post by Pantherairsoft » Sun Oct 09, 2011 4:15 pm
My calibration issues were sorted when I did the last firmware update. Had no problems since. Looking forward to the next update!
JohnH
Post by JohnH » Wed Sep 25, 2013 12:04 pm
HELP!!!!!!!!!!!!!!
I suddenly have a serious problem. After working fine the gas-pedal is not working any more. Calibrating is failing as both positions are giving 0. Please help. I installed version 2.1/349
thanks
John
Del-Uks
Post by Del-Uks » Fri Sep 27, 2013 8:10 pm
JohnH wrote:HELP!!!!!!!!!!!!!!
thanks
John
Exact same problem here !
My Moogs : Minimoog Model D #10790 • Slim Phatty #SP 00433 • Sub Phatty #SUB03422 • MP-201 Multi-Pedal #MP00344 • Moogerfooger MF-104M Analog Delay White Finish #2074 • Moogerfooger CP-251 Control Processor #3962
Del-Uks
Post by Del-Uks » Sat Sep 28, 2013 6:09 am
JohnH : This thread might help you...
It didn't solve my problem, but now... I'm wandering if the infrared LED is not just simply dead ?!?
JohnH
Post by JohnH » Sun Sep 29, 2013 8:52 am
Hi
I tried now several options, and I am indeed afraid that the LED is not functioning, unfortunately. I ordered an new one and once it has been received and tested I will put another posting. Meanwhile all suggestions are welcome.
John
Del-Uks
Post by Del-Uks » Sun Sep 29, 2013 9:06 am
I've contacted Moog Tech Support about this issue... so, stay tuned...
Del-Uks
Post by Del-Uks » Tue Oct 01, 2013 4:53 am
JohnH wrote:I ordered an new one and once it has been received and tested I will put another posting.
Where did you order it ? From Moog ?..
Anyone else here facing the same problem ?!?
stiiiiiiive
Post by stiiiiiiive » Tue Oct 01, 2013 5:21 am
I would write to Moog support directly.
Del-Uks
Post by Del-Uks » Tue Oct 01, 2013 3:30 pm
...still waiting for their answer... I'll let you know.
