Moogertron Mk II Test Panel
latigid on
Post by latigid on » Wed Jul 28, 2010 12:38 am
The next stage of Moogertron: one big panel.
This one is just acrylic, which is too flimsy and too thick to work in the final version.
Designed by brother Pete, now I have to do the electronics.
8x 9VDC powersupply: done
Desolder panel jacks, or extend those which have board connectors
Work in mods (104 spillover, 101 ext. trigger, CV attenuators etc.)
Add bling
The final panel will be made of thin steel and will probably be powercoated and screen printed.
Watch this space!
Andy
ARP
Re: Moogertron Mk II Test Panel
Post by ARP » Fri Jul 30, 2010 9:57 pm
That's gonna look wild !
"Although they heard the music..they didn't understand the tune"
ColorForm2113
Post by ColorForm2113 » Sun Aug 01, 2010 11:09 pm
so....do you think this will void the warranty on your moogs?
but seriously that is going to be insane when its finished! kudos
latigid on
Post by latigid on » Sun Aug 01, 2010 11:31 pm
Heya!
Wait until it's got backlit acrylic letters and fancy gadgets!
Warranty: gone! The ring mods and filter were second hand anyway, the rest well over a year old. The only thing recent was a MIDI MuRF, luckily that won't need desoldering. Hopefully not too many static-sensitive parts... I'm careful.
So I've got all the PCB-mounted sockets off, next is to wire the new sockets so they can sit above or below the 'foogers. And put in CV mods where appropriate. Man it was hard torching the 104SD... please forgive me! :)
Post by EricK » Mon Aug 02, 2010 11:59 am
Im curious as to what made you choose that particular arrangement of Foogers. In my rack I put, 107 102 104z. My other rack is to contain 103 101 105b whenever I get the 105b, and I haven't figured out the order of that yet.
I don't usually keep mine strictly in the audio chain, but the 102 went in the middle because it was the oldest and had scratches on the cheeks so my placement is determined by which one I want to sacrifice the cheek pieces on.
When I get my other rack I might change the order more to the Fooger synth, but I was thinking that the 103, 101, 105b makes a pretty nice filter bank.
Awesome design though...i really wish that I could do stuff like that.
Can't wait to see what it looks like!
psicolor
Post by psicolor » Wed Aug 04, 2010 6:15 am
Looks heavy!
latigid on
Post by latigid on » Wed Aug 04, 2010 5:58 pm
Eric, I think it had something to do with a basic model number order, then arranging the two ring mods and MuRFs together for symmetry. With all the front-mounted sockets, patching is no big deal. It even helps to have a little bit of space between them.
psi, it's not too bad! The first version had lots of wood panels and very heavy sockets (about 8 kg/ 20 lb of metal). This version was designed to be lifted by one person and have a more compact arrangement.
I think the rear will be acrylic (as long as there isn't too much RFI) so you can see all the circuits and the lights peeking through.
David Bulog
Post by David Bulog » Wed Jan 12, 2011 7:29 am
Hi there Im looking at getting HFA Electronics in Auckland to build a 4 x 9V DC powersupply
Im very interested in your powersupply design--can you PM me
CountingToes
Post by CountingToes » Mon Aug 22, 2011 5:30 pm
are there any finished shots of this yet?
MC
Post by MC » Mon Aug 22, 2011 6:21 pm
Probably building a new one to accommodate the ClusterFLux :D
latigid on
Post by latigid on » Mon Aug 22, 2011 6:56 pm
Yeah, probably one of the MuRFs or Ring Mods should be relegated.
I have been terribly slack on this, trying to write up a PhD, but I will have a lot more time when that is done.
Semi-finished:
seank
Post by seank » Mon Aug 22, 2011 8:49 pm
oh my god that is so beautiful. kill two birds with one stone and write a phd about your moogertron. i'd give you an a+.
Post by EricK » Tue Aug 23, 2011 7:22 am
He wouldn't have to defend that dissertation to us!
Nice work! Looks heavy.
CountingToes
Post by CountingToes » Sat Aug 27, 2011 5:20 pm
awesome, really hope you get it finished mate, so good to see things like this, well inspiring,
cheers
digital_steve
Post by digital_steve » Fri Sep 09, 2011 12:35 am
Wow... that's amazing
Mind you, taking apart a 104sd should be against the law!
