visual synth
jeepo
visual synth
Post by jeepo » Tue Nov 03, 2009 3:00 am
Hello, I stumbled upon an interesting, and very entertaining synthesizer program called photosounder, the program uses pictures to play different frequencies, it also allows one to "draw" sounds, i highly recommend you play with the program, as it can be used to create some interesting sounds. More information, and a demo are available on the website www.photosounder.com
Stage II, MF-102, MF-105m, MF-107, paia theremin, akai s2000, yamaha pss 680, yamaha cp 25, and other stuff
Post by EricK » Tue Nov 03, 2009 11:16 am
Is that sort of the same principle behind Reactable?
jeepo
Post by jeepo » Tue Nov 03, 2009 1:11 pm
The Reactable looks like fun as well, I don't know how it works. The program photosounder is more like using a coordinate plane (y-axis is frequency, x is time) to graph sounds, as an example on can load a picture into the program and play it (fractals sound great, due to the math, i assume), or one can "draw a sound in the program, whereas reactable appears to be a control interface. If i am wrong about the function of reactable please correct me.
mayidunk
Post by mayidunk » Wed Nov 04, 2009 12:51 am
Your link did not work. Perhaps this is the link?
http://photosounder.com/
Maskin
Post by Maskin » Wed Nov 04, 2009 6:59 am
Looks similar to Metasynth.
[size=75]"I like to play with electronic noise makers. I hope someone wants to listen, and if not, I'll still be up at 3 am making sequences in the dark, drinking coffee, and burning expensive incense." [i]Rod Modell[/i][/size]
