I have acquired a Source that needs fixing up. The data wheel only increases the numbers, the membrane needs replacing and the VCA has something that needs replacing because the notes ring out. Also a few connectors and their sockets are missing. I am preparing to have a crack at it but I need advice about parts.
Is the membrane ribbon an IDC connector or something special? Also there is a ribbon and connectors that join the circuit boards together that I need to replace. Finally I am missing almost all of the screws. Are they a standard size?
Thanks in advance.
