If you start to make a post to a topic, and decide you don't want to submit it, there is no way to cancel the post and return to the topic.
The best workaround I can find is to hit the "Board Index" button which pops you out of the topic you are in.
I didn't see a FORUM for submitting comments on the Forum design implementation. Not sure if the right folks will see this - but would suggest you create such a forum so you can monitor it properly.
Forum Design Issue: Cancel Post
Re: Forum Design Issue: Cancel Post
This forum is not a Moog built one.The phpBB® Forum Software is used here. Changing and adding such a function takes a while. And all the affords are lost with the next needed update to the forum software to keep spammers and hackers off.
So better post you wish at the phpBB user forum.
Sequence:
Sequence:
- stiiiiiiive
I think the best workaround is rather right-click on the "previous" button of your browser and select the page of the topic you want to get back to.
Thanks for replies.
