Moog Prodigy modulation wheel help
Raptor
Post by Raptor » Sun Sep 20, 2020 8:32 am
Hey there, I’ve got a Prodigy that is in excellent condition. Everything functions properly except the mod wheel just got really tight, and is having trouble moving up and down with fluidity and ease and won’t modulate as it used to
The mod wheel does not hit it’s center notch like it used to, it seems like the notch got bumped out of alignment and is causing the mod wheel to move very tightly up and down
Does anyone know how I can fix this?
Thank you!
atkbg
Re: Moog Prodigy modulation wheel help
Post by atkbg » Mon Sep 21, 2020 8:41 am
I think you'll have to open it up and take a look before anyone can suggest with certainty.
burymyteeth
Post by burymyteeth » Mon Mar 01, 2021 9:04 pm
I had the same issue, has come up twice now. I just took off the bottom plate and sprayed deoxit into the mod wheel pot and worked it in there real good. I don't know if the pot is going bad or what, but has happened twice in the last 4 months or so. Seems to be working fine now.
