Micromoog cv/gate midi cotrollers???
dantanna
Post by dantanna » Sat Aug 22, 2020 8:53 am
Hello forum people, hope everyones good out there....
Any good advice will be greatly appreciated & info on anyone running a midi micromoog setup!!
Thankyou for your time in advance ;)
Over past few months i have been researching and looking at suitable cv/gate midi converters to control my micromoog.
I have found quite a few different types and options (both mass produced & diy kits etc).
In my research of the mcromoog it has been noted that the cv/gate has a fault rendering it requiring 0.99v to operate properly (instead of the standard 1v per octave), as such these are my questions....
1) will the micromoog still operate receiving a 1v signal?
2) will the pitch be affected or will it fall inline with the cv device?
These are the current devices i am considering buying for reference (due to having low funding at present) -
https://www.cykong.com/Synths/Vesta%20K ... oMDI-1.htm
https://www.ebay.co.uk/itm/MIDI-CV-Conv ... %7Ciid%3A1
till
Re: Micromoog cv/gate midi cotrollers???
Post by till » Sun Aug 23, 2020 5:30 pm
You should use a MIDI to CV interface that features a way of handling this. Many interfaces are able to adjust their output to match the synth.
This little less than 1 V/oct was done by intention on many Moogs, as it is not easy to boost voltage, but easy to reduce it. In fact, a single resistor will do the job.
Sequence:
dantanna
Post by dantanna » Sun Aug 23, 2020 7:21 pm
Hey thanks for your reply. Ive not come across any controllers so far that make it clear they can alter cv output.
Could u recommend any please?
till
Post by till » Mon Aug 24, 2020 7:13 am
Pro Solo mk2 and mk3 work fine.
Use the mk2 here.
Sequence:
dantanna
Post by dantanna » Thu Aug 27, 2020 6:15 am
ok thankyou
cmfrick
Post by cmfrick » Sun Apr 11, 2021 11:06 am
Thank you for the helpful thread!
In my studio, I have a Micromoog, a Rogue and a Slim Phatty. So far, I wasn't able to get them playing in sync using cv/gate (and an Arturia beatstep). I understand, the Rogue and Micro have different standards and the Phatty doesn't send cv gate. So - is the only way via Midi and dedicated CV/Gate interfaces for the two vintage Moogs?
Thank you,
Martin
