Hi All,
I'm looking for a replacement knob for my Micromoog. It's the only thing missing from a very nice vintage board.
So 1) are the knobs on the Micromoog unique or were they shared with models other than the Multimoog and 2) any ideas where to purchase?
Thanks in advance,
Johnny
Micromoog parts source needed
Re: Micromoog parts source needed
Did you try searching on eBay? Most propably you can get it from there.
Note: Beware of fake seller, so go with reputated seller.
Hello! I'm also looking for a knob for my Micromoog. Have not had any luck with eBay or Syntaur. Will you keep us posted if you find some spares? I'll do the same for you. Also, if you find a few of them I'd be happy to buy one off you.
I don't own anything that would make you jealous.
My pop recently shipped me my old Micromoog which had been sitting in the attic for 20 years. I had a friend at work fix it up - a bit of cleaning, replace some power supply capacitors, new potentiometer for the mod wheel, new wire for one of the keys. Surprisingly, even prior to the fix-up work it still played in tune with itself.
However, the pitch strip appears to have some kind of internal short and thus does not work. I want to repair it if possible, I haven't found any source for them online except for an ebay store in another country (ebay.com.sg, where is that?) and it isn't cheap.
Anyone have an idea how to fix this thing or build a new one from scratch?
You really need to check the ground on the ribbon controller. If that's loose the ribbon won't work. However I can rebuild them if you need to. Send me a PM.
