Moog Satellite transformer needed
Posted: Thu Sep 01, 2016 8:05 pm
by Tonysal123
Moog Satellite disassembled! And getting ready to replace all the capacitors. This is a European 220vac model, I'm in the USA so I'm also looking to changing out the transformer for 110vac. If anyone knows of any spares please let me know. Thx.
Re: Moog Satellite transformer needed
Posted: Sat Oct 08, 2016 5:59 pm
by noddyspuncture
Tonysal123 wrote:Moog Satellite disassembled! And getting ready to replace all the capacitors. This is a European 220vac model, I'm in the USA so I'm also looking to changing out the transformer for 110vac. If anyone knows of any spares please let me know. Thx.
What are the secondary voltages...?
Tom
Posted: Sat Oct 08, 2016 8:24 pm
by MC
Most transformers by that time have tap wiring so they can be used for either 240VAC or 120VAC. If so, then the only other changes are the fuses. Check the schematic.
Posted: Sat Oct 08, 2016 8:38 pm
by MC
According to the schematic I found, secondary voltages are +/-16V (before the diode bridge). So you need a at least a transformer with secondary of 32V with center tap.
The schematic also does not show taps for 120/240VAC, but the Satellite was built by places other than Moog (they licensed it to Thomas Organ who contracted out the assembly) so designs may have differed.
Re: Moog Satellite transformer- Found & Installed
Posted: Sun Oct 09, 2016 2:23 pm
by Tonysal123
Thanks All for your help, most appreciated. I was able to get a 110vac transformer from Josh at SynthParts. Installed & working perfectly, while in there replaced the capacitors.
Posted: Sat Oct 29, 2016 12:09 am
by dougt
Tonysal123 wrote:Thanks All for your help, most appreciated. I was able to get a 110vac transformer from Josh at SynthParts. Installed & working perfectly, while in there replaced the capacitors.
Actually my name is Doug. :) Glad it worked out.
