Looking for Moog style knobs with a D-Shaft fitting, anyone know where i can get them from ?
Preferrably with a base of 16mm (1.6cm) across, and a height of 19mm (1.9cm)
Re: Moog style knobs with a D-Shaft
Only available from Cosmo in large quantities. Digikey/Mouser/et al do not stock them.
Try Smallbear - they sell several sizes of Cosmo knob knock-offs. No D-shaft types AFAIK, but set-screw versions may work for you just as well:
http://smallbear-electronics.mybigcomme ... red&page=6
I have successfully mounted the set-screw style knobs on a d-shaft pot many times. The only issue I've ever run into is occasionally the d-shafts are a bit longer and the knob has more clearance than needed above the panel.GregAE wrote:Try Smallbear - they sell several sizes of Cosmo knob knock-offs. No D-shaft types AFAIK, but set-screw versions may work for you just as well:
Moog Format Modular
Model D (2016)
Moog Subsequent37
Oberheim OB-6
Sequential Rev2
Model D (2016)
Moog Subsequent37
Oberheim OB-6
Sequential Rev2
