Minimoog Model D: CV control options?
a_i_r
Re: Minimoog Model D: CV control options?
Post by a_i_r » Thu Dec 17, 2015 12:42 pm
I'm happy to use my 201 pedal but don't think it covers all the synth cv inputs I'm looking at, nor does it have a poly mode that I can tell. Any data or reference for the cv voltage ranges would be appreciated. i believe the moogs can handle +5 volts, but I'm unsure if -5 volts is would cover the Full range of sweeping the various parameters mentioned. Thanks again and happy holidays.
a_i_r
Post by a_i_r » Sun Dec 20, 2015 11:51 am
I was able to get the model d midi notes working with a simple converter from eBay and got the 201 to control the filter. I just wish I could get a setup to control all the synths with a single unit. Let me know you guys think the muc unit above or if the Encore Expressionist might do the job. Assuming both work, I think the latter would be better as it also supports din24. The real issue I can't seem to find any data on is what voltage range allows sweeping the full parameter range. In any case here is the model d trial run: https://soundcloud.com/austinindierecords/futuri-mens
