Looks like the Werkstatt-01 will be available for $329.00.
Novamusik and other select dealers are offering a pre-order.
Novamusik per-order Werkstatt-01
Moog Compact Patchable Analog Synthesizer No-Soldering-Required DIY Kit
Front panel
Oscillator section
Single VCO with frequency control (8Hz to 16KHz)
Saw and square waveshapes with control for square pulse width
Envelope or LFO selectable mod source that can be assigned to PWM or pitch with amount control
Ability to PWM the square wave
Filter section
Classic 4-pole Moog Ladder Filter with resonance control (20Hz-20KHz)
Select between the envelope generator and LFO as mod source
Polarity switch (+/-) and amount knob for control of filter cutoff modulation
LFO section: selectable square or triangle waveshape with rate control (2Hz-600Hz)
VCA/amp section: select between the envelope generator or on/drone
Envelopes section: controls for attack and decay time with sustain on/off switch
Keyboard section: one octave low-note priority legato keyboard with glide control
Patch panel
VCA input
0V to +5V in VCA envelope generator mode
+/-2.5V in VCA on/drone mode
VCF input: -5V to +5
VCO linear FM input
+/-2.5V
Note: this is an inverting control input
VCO exponential FM input
-5V to +5V
1V/octave trimmable
LFO CV input
5V to +5V
Note: negative CV slows LFO more than the panel control
VCF audio input: unbuffered/unmixed AC coupled input to VCF
2 × keyboard CV output
3V/semitone from 1 keyboard
Note: attenuate for 1V/octave
2 × trigger output
5 msec pulse
0 to +5V signal generated from low-note priority
2 × gate output: 0 to +5V signal generated from low-note priority
2 × envelope generator output
0 to +5V signal
Simple attack/sustain/decay or attack/decay type envelope generator
2 × LFO output
-2.5 to +2.5V triangle or square wave
Wave selected by panel LFO wave switch
2 × VCF output: -2V to +2V signal for audio or CV uses
2 × VCO output
0V to +5V VCO signal
Wave selected by panel VCO wave switch
Rear panel
Audio output: nominal +/-1.5V signal
Power
+12VDC center positive with 1.2A wall transformer
Power consumption: 1.8 watt average
The Werkstatt 01: Moogfest 2014 Kit is a patchable and compact one oscillator analog synthesizer. It was originally created as a kit to be the foundation for exclusive 'Engineering VIP' workshops at the Moogfest 2014 festival. Due to a number of requests, Moog is offering a no-soldering-required version of the Werkstatt 01: Moogfest 2014 Kit in limited quantities.
Assembly is extremely simple: any user can quickly build an analog synthesizer based on classic Moog circuits and, if desired, modify it. Werkstatt was created to be an educational tool, but it is also a very powerful, compact analog synthesizer from Moog.
Werkstatt is 100% US made.
