COMING NAMM 2014
thealien666
Re: COMING NAMM 2014
Post by thealien666 » Fri Jan 24, 2014 1:00 am
@EricK
Look closely at the nameplate on the bottom right, Bob's signature is right there...
http://www.sweetwater.com/images/items/ ... xlarge.jpg
Moogtard
Post by Moogtard » Fri Jan 24, 2014 1:15 am
Sweet! I must say the panel and buttons strike me as very DSI-ish. This thing will look great next to my Little Phatty Tribute Edition! Probably will sound good to. Ha
Fantastca
Post by Fantastca » Fri Jan 24, 2014 9:11 am
I spotted some interesting difference between Sub Phatty Oscillators and Sub 37 Oscillators.
On Sub Phatty the range is from 0 to 12 (same with sub osc and noise) and on 37 the range is 0 to 10.
Is it something worth mentioning?
Moog Sub Phatty (firmware 2.1.12 beta, editor 1.1.0) | Ableton Live 9.7 | macOS Sierra 10.12.3
XAXAU
Post by XAXAU » Fri Jan 24, 2014 2:02 pm
Fantastca wrote:I spotted some interesting difference between Sub Phatty Oscillators and Sub 37 Oscillators.
I think with the feedback you won´t need the extra boost into the filter! :lol:
thealien666
Post by thealien666 » Fri Jan 24, 2014 2:16 pm
You're talking about the mixer section, right ? I don't think that those markings are in db values, otherwise they would have been indicated as such. I think they're just for positional reference purposes.
Post by EricK » Fri Jan 24, 2014 2:47 pm
I saw that on the panel, but I was talking about on the rear extrusion that faces the audience.
Did you guys seen the full sized MS-20 kit from novamusik?
thealien666
Post by thealien666 » Fri Jan 24, 2014 3:17 pm
Yeah, about the MS-20 full size kit, have you seen the price ??? You'd be better off finding a used one already assembled...
Usually kits are less expensive than the assembled product (mini version or not), not the other way around.
Post by EricK » Fri Jan 24, 2014 5:10 pm
I wonder if it's the same boards as the mini version.
thealien666
Post by thealien666 » Fri Jan 24, 2014 5:29 pm
I doubt it. The mini version used 1/8" jack instead of 1/4", and the pots were smaller too...
And, it's not really a kit in the traditional sense. The PCBs are already fully populated...
torinkrell
Post by torinkrell » Fri Jan 24, 2014 8:45 pm
Several of my friends and I are very impressed with the Sub 37! It really is great to see how many forum and user suggestions were implemented in the Sub Phatty's big brother. There are also several good feature suggestions in this forum thread that could still be implemented before the actual production date a few months away. My own suggestion is to add a switch on the front panel to select between low or high priority keyboard triggering. Since the "duophonic" implementation here already makes use of most of the necessary circuitry to make this possible I don't expect this to be a difficult feature addition. As many of us here know, some vintage Moog synths like the MG-1 have high note priority as do some other monosynths like most or all of the monophonic part of the Yamaha CS series.
Akai AX-80
Korg Polysix
Roland Juno 60
Moog The Source
Yamaha e1010 BBD
Moog Parametric EQ
Sequential Prophet Pro~One
Altec AS-1600 audio oscillator (1947)
Moog Music Minimoog Model D (1973)
unfiltered37
Post by unfiltered37 » Fri Jan 24, 2014 9:55 pm
Well obviously. The Sub 37 is 2 louder. They were going to have it go to 11, but why not 1 more?
eXode
Post by eXode » Sat Jan 25, 2014 7:28 am
He said that the Sub Phatty goes to 12 and the Sub 37 to 10. How do you make that into the Sub 37 is 2 louder? :P
stiiiiiiive
Post by stiiiiiiive » Sat Jan 25, 2014 8:14 am
torinkrell wrote:My own suggestion is to add a switch on the front panel to select between low or high priority keyboard triggering.
Just on the left of the DUO MODE button :)
unfiltered37
Post by unfiltered37 » Sat Jan 25, 2014 10:22 am
eXode wrote:How do you make that into the Sub 37 is 2 louder? :P
I guess you haven't seen "This is Spinal Tap".
JohnLRice
Post by JohnLRice » Sat Jan 25, 2014 10:58 pm
Part of the Moog friendly Moon Modular booth at NAMM via Russ and MatrixSynth:
John L Rice
