Share your synthesizer music!
GregAE
Re: Share your synthesizer music!
Post by GregAE » Thu Dec 17, 2015 7:45 pm
Kenneth wrote:Greetings, Moogers! The sounds are all from the DSI Pro-2 (I sold my Voyager to get it :shock: )
Moderators!!! Where are the moderators? This guy needs to be banned!! Sold his Voyager for a Pro2?? Heretic!
<< calming down now >>
Cool track! :wink:
- Greg
Kenneth
Post by Kenneth » Sun Dec 20, 2015 9:37 pm
Cool track! :wink:
- Greg
I know, I know! I regret it quite a lot, actually, and thought about selling it to get another Voyager. But, in the end (for now) I decided to stop comparing them and just make music. The Voyager, while being a relatively simple monosynth, sounds better than any other synthesizer I've played. The Pro-2, on the other hand, can be rather tricky to program, and doesn't always cooperate with your intentions for it. However, it is capable of a mind-bogglingly wide scope of sounds, and I do feel as though I've learned a bit about more complex techniques in subtractive synthesis. The two are apples and starfruit.
I don't own anything that would make you jealous.
JohnLRice
Post by JohnLRice » Thu Dec 24, 2015 3:08 am
Merry Christmas all! (yes, some actual Moog content in this one! ;-)
https://youtu.be/apS8Z4hyRE0
John L Rice
mlekoman
Post by mlekoman » Fri Dec 25, 2015 11:33 am
Hi,this is recording I made about year ago. Most tracks were made with Minibrute... no moogs yet because I ordered my sub month after making this piece :)
https://www.youtube.com/watch?v=puNyafCSMqo
I hope you'll enjoy it :)
chekmate99
Post by chekmate99 » Sat Dec 26, 2015 11:39 pm
Here is something I made this evening for a home video soundtrack, it's something like Carpenter Meets Aliens...
https://soundcloud.com/chekmate-99/carpentervsalienmp3
jido-genshi
Post by jido-genshi » Tue Dec 29, 2015 3:09 am
Here's a video of a performance I did this past Saturday for an Ambient/Drone event. The event was held at a beautiful Masonic Lodge built in 1921. I used three Moog Mother-32s and a Kilpatrick Audio Phenol with a few effects pedals (Eventide H9, Strymon blueSky and El Capistan.) If you are patient, and have a good pair of headphones, you may enjoy this... https://www.youtube.com/watch?v=7ap4fpzx5cs
potts1970
Post by potts1970 » Sat Jan 02, 2016 12:03 am
I posted this in the Mother 32 area but deleted it since it wasn't really the place for it. Then I found this topic. Here is a track I did a couple of days ago. It's the first minute of the 3rd Brandenburg Concerto, 1st movement in the style of Wendy Carlos. I just did the first minute as a test to see if I could do it. I have 2 Mothers though I only used both twice: for a doubling of a square wave patch to give a warm chorusing effect, and a patch that needed a bright filter attack and a 40% open filter for the sustain since the toggle switch sustain won't allow for an ADSR type envelope. 18 tracks of Mother 32 overdubbed. No other instruments are used. All apologies to the great Ms Carlos on using her style (and sounds that are reminiscent of Switched-On Bach)!
https://soundcloud.com/sgraham27-1/m32- ... al-mix-mp3
noddyspuncture
Post by noddyspuncture » Sat Jan 02, 2016 2:18 pm
potts1970 wrote:I posted this in the Mother 32 area but deleted it since it wasn't really the place for it. Then I found this topic. Here is a track I did a couple of days ago. It's the first minute of the 3rd Brandenburg Concerto, 1st movement in the style of Wendy Carlos. I just did the first minute as a test to see if I could do it. I have 2 Mothers though I only used both twice: for a doubling of a square wave patch to give a warm chorusing effect, and a patch that needed a bright filter attack and a 40% open filter for the sustain since the toggle switch sustain won't allow for an ADSR type envelope. 18 tracks of Mother 32 overdubbed. No other instruments are used. All apologies to the great Ms Carlos on using her style (and sounds that are reminiscent of Switched-On Bach)!
Sounds excellent... was it played by hand too...?
Tom
potts1970
Post by potts1970 » Sat Jan 02, 2016 6:32 pm
Thank you! No it's not real time finger busting. I should have noted that. My timing is not THAT good especially at that speed!
I took a mutiltrack MIDI file, stripped out the CC and patch info. Everything but note on/note off info was kept. Moved the filter and modulation points by hand to emphasize certain notes of the counterpoint. A primitive touch sensitivity so to speak. The assignable patch output DOES do velocity but I don't use it for that, I have one output do sample and hold and the other to advance the second M32 sequencer to stack them. I like using "perfectly perfect" MIDI info and then breathing life into it. The original multitrack MIDI file is dreadfully monotonous as well as awful sounds (General MIDI is what it is..). Each track it played from the sequencer into the M32 and routed to an audio input as I manipulate the knobs while it records the audio. Then move onto the next instrument, do the same (repeat till completely sick of the piece!). My sight reading has turned to mush since college so I'm better off using MIDI files for a base to build upon. If fact it was weak to begin with!
namahshaman
Post by namahshaman » Wed Jan 06, 2016 2:06 pm
Here's some rather cinematic music I recently made using synths and samplers...and Logic Pro X. Quite a bit of Moog and Moogerfoogers used throughout. I've been working on my mixing skills, so I invite any and all criticism that will help me improve. Cheers and Enjoy.
https://soundcloud.com/namahshaman/sets/reifier
lvdtsimulator
Post by lvdtsimulator » Sat Jan 09, 2016 4:48 pm
I have an album available on CDBaby, iTunes, Amazon, Google Play. My band's name is LVDT Simulator and the album is called November. I made a youtube video of one of the tracks: https://www.youtube.com/watch?v=NCXrhYg6WEo
Sub 37, MOX8, Z-1, D-50, D-110, NS5R, DS-8, PK-5A
Flareless
Post by Flareless » Sun Jan 10, 2016 10:37 am
Here is an album my 2 piece band Fizzbin created called Lost In Spaces. The tracks were created with a Korg MS2000, Yamaha XF6, Synthesizers.com modular, PAiA 9700 modular and to round it out a Moog Sub 37.
In addition here is a track I wrote just after Leonard Nimoy passed away earlier last year. It's a sort of dirge called Bye Bye Spock, Bye Bye. Here is the story behind its creation.
I hope you enjoy the tracks!
Rich
thealien666
Post by thealien666 » Mon Jan 18, 2016 1:35 am
For Giorgio Moroder fans: "If you weren't afraid"...to listen. lol !
My humble cover of this song, from the famous 1979 album E=MC2.
Enjoy !
Synths used: Minimoog D, Korg DW8000, Alesis Ion. All played by hand (no sequencer) following the drum machine (DR-880 with custom TR-707 kit).
https://soundcloud.com/thealien666/if-y ... r-by-alain
hieronymous
Post by hieronymous » Wed Jan 20, 2016 5:57 pm
Haven't posted here in a while - even though not an explicitly synth-oriented piece, it includes some Moog elements:
https://soundcloud.com/hieronymous-seve ... ound-seven
The bass on the intro is filtered by my Big Briar MF-101 (the drums are filtered by the Resonator high-pass filter). The "Taurus Bass" under the solo is Little Phatty - just tweaked "Thank You Bob" - basically the only patch I seem to use! The vibes on the outro are extended with Big Briar MF-104 analog delay.
(And the bass is a fretless Alembic Series I in stereo - neck pickup clean, bridge pickup through distortion)
Struble
Post by Struble » Thu Jan 21, 2016 2:51 pm
http://illiteraterainbow.tumblr.com/pos ... e-ive-been
To learn more about song structure, I’ve been working on cover songs of other people’s stuff. Here’s a cover of the Buzzcock’s Ever Fallen In Love (With Someone You Shouldn’t’ve?) I asked Sam from the Blank Men to collaborate with me on this to try and get more of the synth-punk sound that I hear in my head. Because we both have multiple S initials we decided to call our band Alliteration.
Alliteration is:
Shaun Steven Struble (Ira Virus) – Synths, Drum Programming
Sam Swanson – Bass and Vocals
Equipment used:
Syntecno TeeBee – Main riff
Korg Volca Keys – Accents
Wayfar MidiNES – Chorus power chords
Fender Modern Player Dimension – Bass
Korg Electribe ER-1 – Drums
http://DepressedBoy.com
Equipment: Moog Werkstatt; Arturia Microbrute; Syntecno TeeBee; Elektron Sidstation; Korg Volca Keys, Electribe ER-1, Monotron; MidiNES; Teenage Engineering PO-12; Roland Boutique JP-08; BeatStep Pro; GameBoy
