No problem - I'm glad it was of use! If you want more in-depth info about the CP-251's module functions, look at the CP-251 manual over at moogmusic.com.sallyguzman wrote:Thanks for the info!!...Really helped
David.
NZ
Make sure you check out my post on using the FreqBox as a SubHarmonic generator...red wrote:I will also use the trio as stand alone source of new sounds - or in any combination with sounds from other sources.
It's a sign of the times (and marketplace) when the MacBeth gets a (big big big) wow!!!!! and the Sub-Phatty gets unnoticed , almost.thealien666 wrote:Yeah, nice bokeh there, fyvewytches.
You and I would make great, great friends.Mudfuzz wrote:I haz a second freqbox coming! So I can run two parallel. Also got a bunch of cords and a Fernandes Vertigo X for $73 [which is a freq'n awesome guitar really... well once you change the pickups...]
also haz a Ventura MIJ lawsuit EB2 copy body and neck coming for a possible EB6 project...
