Got a small problem with my MM+.
The most that I can adjust any setting to is 096. It's a small problem, not really too big of a deal, I was just wondering if there's anything that can be done to easily fix this. I looked in the service manual, but found nothing. There is a minor noticeable effect, for example the pulse width won't adjust all the way at the max value, and you can still hear the wave a bit. If it's a hard repair that would have to be done, than I won't worry about it. But if it's something simple, then I'll give it a try.
Memorymoog adjustment question
Re: Memorymoog adjustment question
I once had a MM repair likt this - it was a bad cap in the S&H.
