I’ve been doing a lot of ambient music with the Voyager (Select Series OS 3.4) and I am noticing zippering when manipulating controls while playing sounds. Particularly when moving the filter cutoff.
Where someone mentions a “dodgy” MIDI cable being the source of the problem. I pulled the MIDI Out connection from the Voyager, voila, no zippering! OK. I swap cables. And with another cable, I have the same problem.
So what am I missing here? No MIDI cable connected to the MIDI Out = no zippering. Could it really be two cables that otherwise work fine causing the zippering sound?
Thank you for the replies guys.
I don’t believe I have a MIDI loop. I am not sending MIDI in or out in the app I am presently using. But I am using the Voyager Librarian that does.
That said, I get the stepping with the Voyager Librarian inactive.
I’ll try Rudi’s suggestion later on tonight. Hopefully it does the trick!
