XL ribbon CV out not sending CV?
Hey Guys,
I hadn’t used my ribbon controller in a while and I decided to patch it in this morning. It seems it’s no longer outputting a signal any more - or, at least, it’s VERY weak. For instance, when I patch the CV OUT to the FILTER CUTOFF, nothing really happens when I sweep the ribbon. When I send it to the attenuator and jack up the settings, I can faintly hear a change when I sweep the ribbon. The GATE OUT works as it should just fine. So I believe the ribbon, itself, is fine. Have any of you run into this issue before where an output stops sending a signal?
Thoughts?
Send it to a pitch and see if you can get more response.
This is weird. I had the XL on all morning (ample warm-up time). I was sending signals straight from the Ribbon CV OUT and not getting any changes - it seemed to only be sending about +/-1v, if that… I tried different patch cables and different inputs to test the signal. I then tried going straight out from the Ribbon Attenuator while making adjustment to the AMOUNT and OFFSET. I finally started to get changes… I then plugged back into the Ribbon CV OUT and now it seems to be sending the full +/-5v.
Very strange.
isn’t the ribbon CV normalized to one of the attenuators, even when it’s not patched?
Yes, it’s normalized to Attenuator 2 (Attenuator 1 is normalized to LFO2).
I’m guessing I can just chalk this up to analog behavior. It didn’t work, but then it did. :confused:
