Hi, dose any one know if the mult on Moog gear is buffered?
cheers
cheers
Usually, by definition, a multiple is not buffered. It’s simply three (or more) connectors connected together.
Most, if not all, of the possible modulation destinations usually have buffered inputs with high impedance, eliminating the need for buffered multiples.
I’m pretty sure the multiples on Moog products are standard, unbuffered.
Cheers mate ![]()
not buffered indeed.
( on the roland sys100m i think they are buffered though, on lot of other modulars not )
Not Buffered. Most of the time, it isn’t a problem. It can cause voltage sag and or droop if you try to split it over too many devices. Building a buffered mult isn’t difficult if you ever find you need one. (There is an easy to build unit explained in the Encore Expressionist breakout mod page.)
