Hey,
When openeing a Project that uses the VST (x64) editor it Changes the preset and presetname on the Sub37 to what the VST settings was.
Tho presetname in the VST is empty.
Also, if i in this case remove the VST and i choose the VST again. The patch i had on the the Sub37 Before opening the project will now be active and thoose settings will also be in the VST and showing the correct presetname.
OR (just noticed)
If i just click the Librarian button on the VST it will change to the patch i had on the Sub37 Before openening the Project.
Im using the VST as insert in Cubase Pro 8.5 (64bit)
I hope you do understand what i mean ![]()
Kind Regards,
Carsten
