Will this work?? S&H
I control the cutoff on MF-101 with the pitch-antenna on my theremin.
I want send the pitch-CV through sample and hold on CP-251 and set up MP-201 as a trigger.., Now, when I then adjust the cutoff(with the antenna), can I trigger the “S&H” so the cutoff stays at that exact position for as long as I want until I trigger it again?? Or is the “hold” time-limited depending on the LFO?
Havnt really used Sample and Hold before.
If this works Ill buy the CP-251…
Ill buy it anyway :smiley:
Brilliant device!
I can’t tell you anything about the mp201 because I don’t own one.
I would run the audio to the 101 as you would normally. Then runs something (like say the gate output from the volume antena or a gate signal from the 201) to the S&H trig input. S&H outto cutoff freq in. This will allow you to randomly change the cutoff freq when you activate the vol antenna gate.
When you use the trigger input, I believe that it disconnects from the LFO. I like to use the Voyager’s touchpad to this input and then get a random voltage whenever I hit the touchpad.
Yes, I can send a gate signal from the mp201. Great! Then its gotta work..
This is gonna be so super cool. Cant wait to pick it up tomorrow.
