Will I do damage if I go from my pitch out on the lp to the freq in of the freq box. Then go from the osc out of the fb to the audio in on the lp? I’m mostly concerned with putting a voltage signal on the audio in on the lp.
Nope. I do that all the time. The only issue I have with it is that the voltage on the OSC out of the FB is pretty hot, so it has a tendency to over power the LP oscillators… And because the LP has no volume controls for audio on the external input, I use an attenuator to get the volume of the FB osc just right…
