whistling noise
Hello everyone I have a moog voyager AE, at his side there is a fender rhodes
if the fender is too close to the moog you hear a whistling noise as the backlight, the more it is far less noticeable if I sconnetto the cable from the fender and the approach the moog noise increases, I tried to bypass the backlight opening the moog the problem is solved.
you have any advice to avoid eliminating the backlight and the noise?
thanks
