Having patterns for the arp that arenāt of the same note length (swing?)?
Is there any easy way to do MIDI latch or did I miss it?
Ideally I would be able to press 3 keys down, have that arp play, and then play on my other keyboard, then go back and press down another set of keys and have the arp change. Basically, Moog accompanyment. If thatās already doable, great, I am just not sure how to access it.
Velocity sensitivity that affects volume instead of just the filter could be very nice to have too.
Iām cool with everything but I really need a legato glide mode⦠no glide with short notes and glide when notes overlap. irregardless of ENV trigger mode to have the option of having envelopes re trigger or not.
Itād be a very nice feature. Itās supossed to be already on the wish list, if I remember right, and since it shoulnāt be very difficult to implement I guess weāll see it sooner or later.
I realized yesterday that its not in the Voyager either⦠I guess if your using an analog sequencer that has slide(glide) on a per note basis then you donāt need that mode in the LP or the Voyager to exist as long as your going CV GATE into them, but if your using a MIDI sequencer you have to have it, as all the sequencer will send is a slight overlap for legato on that selected note⦠and velocity for accent.
Accent in most analog sequencers of the step type is available as an output, so that can be sent to the VCA as CV and get that extra āvelocityā bump per note.
but It be awesome to use some of these new MIDI sequencers like the NEMO or the Schrittmacher on Moog gear and have it really do nice organic patterns ādroolsā
