Dont forget about the signature edition 104’s from the homepage. But if thats not your thing, check out novamusik because with a Fooger, they include an ep2, Fooger DVD, T shirt so you can talk them down a bit off of their price. You get more free stuff when you order more. THey will be happy to serve you!
I think that the Ring Mod has a lot to offer. Frankly its just a wacky effect, it really gets some 70’s sounds out of it which can be anywhere from subtle to invasive, and its very versatrile.
Its a good one to couple with the delay, but a classic is the phaser/delay combo and you still get the LFO to boot.
Heres me
102
I have the 104 102 and 107. I play more instruments than just keyboards/synth and Ive ran vocals and other instruments through the ring mod. I usually refer to this more than any other pedal. Its good in the effects send, its good in the audio chain. Its good for modular style funk. I like to keep everything in the audio chain every now and then and control the FOogers with the mix. So I have a complex evolving patch on the voyager or whatever and then Ill reach over and tweak the Mix on the ring mod for some added goodness. Keep in mind that the Ring Mod will also track the Voyager and you can get more waves out of it by reading Gregs article on Knob Tweak.
104
I didn’t use to run EVERYTHING through delay until I got this one. I think it is so warm, when i turn it on my other Oscs go unstable! Its a great 1 trick Clydesdale!
107
I run different instruments through this one ocassionally. I bought the Freqbox because I was supposed to be getting a 921B but someone decided that they were going to send me a bill so Instead of the 921B and power supply, I got the 107/Cp251 combo. I bought this for its Osc capabillity since I had to sacrifice the 921b. and at the time I didn’t own a Voyager. I don’t use it nearly as much as I use the RIng Mod. Once I got to messing with this unit I fell in love with it, but it still doesn’t get a whole lot of usage with my Voyager, and thats not because I play every day and choose not to use it, its just because I use it mostly with other instruments. I think this really shines as a synth addendum to a non synth instrument, but it also performes extremely well as an extra osc, especially one controlled by something like a sequencer or Cp 251.
Honorable Mention:
CP251
Consider this with your voyager or your delay. Lets Face it, partner, you will have more Foogers so you might as well get this one sooner or later. You will be able to control a lot of things with this unit.
Another Honorable
Vx351
This pretty much enables you to have ultimate interface with your voyager. Inagine having VC delay with the touchpad! (or did you go back tro the OS?) Anyway you still need this one. Imagine envelopes controlling the mix of the ring mod or the velocity controlling the pitch of another oscillator!
ALso worth noting.
Mp201!
You can get yourself a dotcom sequencer.
