FIrst, the knob-per-function interface will spoil you quickly when you play another synthesizer with similar parameters.
The sound cuts through the mix extremely well.
They keyboard feels wonderful, The pitch and mod wheels are very smoothe and all of the pots are sturdy.
The Voyager is a well made, well designed piece of engineering, and its sounds are fantastic.
This, simply put is the best monophinic synth on the market today.
If its basic features and sounds aren’t enough, it does have stereo outs, an effects loop, and audio input.
This is a great synthesizer upon which to learn, and a seasoned synthesist will still not run out of ideas.
If the basic modulation patching isn’t enough, the software allows for programmable mod sources and destinations.
Filter pole selectabillity is from 1-4 poles.
Dual filters that can be set to bandpass mode.
Extensive Midi control, pots can control other pots and can be chained together so one turn of the knob does quite alot.
If thats not enough for you, and you are interested in going to CV, the Voyager sports several cv inputs of various parameters for usage with other analogue gear.
If thats STILL not enough to wet your whistle, then when used in conjunction with an editor librarian, you can remove the entire banks of 896 presets and store them while you create 896 more sounds. You can also warp two presets together or have your computers sequencer turn every knob for you during a live performance so you can focus on playing.
Finally,
if the features and presets aren’t enough to make this synthesizer about as good as it can possibly get for a potential buyer, then consider that its features are constantly being improved upon. Since its release it has undergone hardware and software upgrades, and with our (the users) input, Moog continues to hone this synthesizer little by litle into the perfect machine. Whats in the future for the Voyager? Perhaps more memory, more destinations, a software based arpeggiator or sequencer, whatever the good people at Moog decide to add to this beast, that is usually just a simple Midi upgrade away.
Verdict?
