My Micro could use a nice exterior cleaning. Any safe products you recommend?
not sure about cleaning but let’s see this little bargain you grabbed…
I used Armor-All for years, no problems.
I hope you mean with “exterior cleaning” all parts of the housing outside, not metal outer patrs like jacks, etc.
I cleaned my Minimoog and Polymoog recently just only with 95% alcohol and the result was perfect, black and dirty cleaning cloth and shiny sufaces at the end. For the wooden parts I always take shaftoil from the gunmaker. Gives you also very good smell.
As well did my tech with the T1 a few years ago.
But I think simple oil can do the job as well as I used also from time to time.
DONT RUB TOO HARD :slight_smile:.....................I mean, on th the instruments surfaces… ![]()
There is this really cheap cleaning supply called “Awesome” which is…awesome. Needs to be diluted a little but man will it really make stuff look brand new.
yes, definitely just exterior as in knobs, casing etc. will use alcohol
Thanks ![]()
NO CHEMISTRY, NO CHEMICALS, or little as possible, Ladies and Gentlemen…
I’m with Megavoice. Warm water and terry cloth or Tshirt material.
