well this was convienent...
I had an ep-2 question and poof controller forum!..hmm I would also like a free Voyager… eh… nothing, oh well on to my question. Can the ep2 pedal be tightened? I just got mine today and it seems a little loose. It will stay in the up position but not completely up sometimes. Thanks
Hello there!
Yes the EP-2 can be tightened to your satisfaction. If you look at the pivot point, you’ll see there’s a 10mm hex bolt there. With a 10mm socket and wrench, you can adjust the pedal tension to your own custom level of resistance.
Amos
fabulous
