Hi David,
I guess the MIDI message is Local Off or so. What software version is in your Voyager? What message on the display can you see when you switch off and on the Voyager when the problem occured?
Have fun,
Rudi
Thanks for the help/suggestions. I’ve not pinned down the exact midi message, but I think the setting is in the Master menu, 1.2 Local Control. For some reason, the crash in Sonar sends a message which turns off local control.
There is no error message displayed, the voyager turns on like normal. Everything else seems to function just fine.
My plan is to not use the plugin which is crashing Sonar. With the Voyager and other hardware, I don’t really need the soft synthesizer anyway
The 3.4 version shows a screen with the local settings after power on if one of the local settings is off. Maybe there’s an older version on your Voyager.
Have fun,
Rudi
