My SP has been giving me a weird chorus/reverb/delay effect. I have the newest Firmware, updated a few days ago. The problems been present prior. I tried leaving it on for an hour before use to see if the problem persisted. It definitely did.
Is it the same if you listen through headphone directly from the phatty?
How is the audio routed? Through computer? Any daw program or something that creates parallel audio routes with difference in latency?
Iāve actually never listened to just the moog in that way. Iāll check and get back to you. Just listened through the Moog itself⦠The effect goes away.
But audio is routed: Slim Phatty > Focusrite Saffire Pro 14 > Ableton 8.2.1
Does your sound card have direct monitoring?
And it may be able to route the sound both to Ableton and to the monitor output by some routing matrix.
Try to turn it off.
I donāt know how Ableton works, but with RME Fireface and Cubase I can get that effect i different ways. But it is always about parallel signals that has a little difference in delay.
You can get a delay like this in Ableton if you use the External Instrument. If you connect your phatty to the audio interface, and set the external instrument to receive audio from that same channel, AND you have that particular channel turned up on the audio interface (i.e. have the āmonitorā knob on the focusrite turned up), youāll get a little delay in the audio coming from Ableton.
I would def check the monitored output of your audio interface and in ableton and make sure only one is selected.
On the other hand, it can make the phatty sound pretty epic. Iāve actually gotten this āproblemā before and said āTHATS BAD ASSā and threw a short delay on the recorded audio to get the same effect on the trackā¦
The effect is really really sick if used right. Itās just not so pleasant when you want to make a really strong bass patch. With this error, it actually allows me to play chords, as long as I hit and hold them in an arp fashion.
