VX-351 outputs -5V
As per the manual, my VX-351 sends -5 to +5V on its vel, pressure and mod wheel outputs, among others. This seems a bit odd and non-standard. The modular gear I’m connecting to expects 0-5V. Do I need to build a set of level shifters, is there a secret hidden switch to change the levels or am I missing something obvious here? Thanks
ps I’m an electronics engineer and I think my preference here is to modify the VX internally. Is there a schematic anywhere? Thanks
Why do you want to do this? Are you trying to get the full sweep of the knob to operate between 0 and 5 V? That’s more involved then a simple blocking diode. The voltage of these signals is generated from the Voyager, not the VX-351. If you’re planning on modding the VX-351 which is a passive device you’d probably need some kind of power supply for active components needed to level shift the signals.
You never anticipate having external modules that need -5V to +5V? Are you aware that most of the the Voyager CV inputs operate between -5V and +5V?
Btw schematics for Moog products are not made available.
Why? I said: The modular gear I’m connecting to expects 0-5V. I want zero aftertouch to give zero CV modulation.
The VX-351 DOES receive +/-15V from the accessory port so I could add active circuitry if I wanted.
Moog do not make schematics publicly available but someone somewhere does have some and maybe they are available unofficially somewhere…
I have added four level shifters in the back of my modular rather than inside the VX where space is more limited.
This is precisely why MIDI was invented: there has never been an industry standard on CV ranges and trigger voltage/polarity.
Like everyone else since the 1970s, you had to build converters to get synthesizers to talk to each other.
Ah ok - makes sense. I was thinking more about the “among others” . I typically run these VC signals into VCAs for level shifting/bias but understand not everyone wants to spend the money or take up space on these type modules.
Didnt know about the +/-15V on the acc. port - tnx.
