VX-351 Faulty S&H Smooth output?
Okay, I know the answer to this but will ask anyway..
Finally got to have a proper play with my VX-351 tonight. With a very simple setup:
  1. S&H Step output into my MS20 Filter control
you get a S&H modulated filter cutoff on the MS20. Nice and random, ranging from fully closed to fully open as expected.
However,
  1. S&H Smooth output into my MS20 Filter control
this result in no modulation! I am expecting exactly the same as in 1 but ‘smoothed’ version. There is definitely no modulation going on..
So, its faulty I presume? Not a problem if so as only a couple of weeks old so well within guarantee..
Thanks for any comments..
Have you tried going into your voyager? Could it be a V/Hertz problem?
Hi - yes, I have tried this. The effect (or lack of) is the same if I try to modulate the MS20 or back into the Voyager. Besides, the MS20 is only Hz on the keyboard triggering, everything else is standard volts. Also, I am successfully modulating everything with everything with my Voyager/MS20 setup, it is just the Smoothed S&H that has no effect (and Noise as discussed in another thread).
Thanks for the reply,
yes it sounds like its broken to me. mine works as expected
Thanks for the replies on this. I got a replacement yesterday from Turnkey and all is now well. Was planning on going on Thursday but decided against it!
Have not actually tried all the functions yet but the smoothed S&H and noise both now work.
Thanks again,
:slight_smile:
