VX-351 Faulty Noise output?
Okay, now testing the Noise output and this looks faulty also. I presume this is a audio output and not a CV output? Either way, I have:
  1. turned off osc 1-3, leaving Noise on. Played some notes so I can hear the noise out of monitors. Muted the Voyager on the mixer and plugged some headphones into the 351 noise output - silence.. So, I can isolate and identify noise out of the Voyager but not out of the 351..
  2. Just in case it is a CV noise source I tried to get this to modulate, say the filter cutoff. It has no effect..
So, does it sound like this is faulty or am I not testing it correctly?
Many thanks,
broken as well. you should hear the noise and be able to modulate with it regardless if the noise switch is turned on or off
Thanks for you reply to this and my other post. I’ll take it back and get another..
See you,
no problem,
dont forget to try the cable as well, the problem could be in there.
good luck
Yep, it was faulty. Got a new one yesterday so thanks for the replies..
