Voyager XL Patch (My First Post)
Hi everyone,
I am new to the forum and somewhat new to synthesis, but I thought I’d share a patch I just came up with. I was wondering whether it was possible (on the XL) to delay LFO modulation triggering when a note is played (i.e. you press a key and it doesn’t start modulating until a second after holding the key down). I don’t have it perfectly but I think I have it pretty close, so I’ll share the patch:
set LFO sync to KB
patch triangle (or other shape) LFO1 → attenuator 2 in (adjust voltage to change amplitude)
attenuator 2 output → CV input (modulation destination of choice)
square LFO2 negative voltage output → LFO rate input
KBD gate out → LFO2 clock
Use LFO2 rate to set when LFO1 “triggers”
When triggered, LFO1 will modulate at a moderately fast rate when set to 0.2 (lowest). Sweeping past that will generate very fast spikes in rate.
If a slower rate when triggered is desired, make the following changes:
LFO2 negative voltage output → attenuator 1
set channel 1 amount to +5
attenuator 1 output → LFO rate input
adjust channel 1 offset to control triggered LFO1 rate
Like I said I’m new to this so this may be more convoluted than it needs to be, or there may be a more accurate way to achieve the same effect, but it seems to work nicely for me so far. Technically LFO1 doesn’t trigger on like a gate but oscillates very slowly until LFO2 bumps it to a noticeable rate. Let me know what you think.
Thank you
