Hello - i’m going to give you as complete an account as I can of this problem, so plese bear with this rather lengthy description. I’m looking for anyone who has experience with any of these problems, so I can begin to rule out causes.
I bought a Voyager EB #0048 from Woodwind and Brasswind a few weeks ago. It was listed as a b-stock, but sold as new with full warranty (which I sent in a week or two ago). The exact nature of why it was sold as a b-tock isn’t clear to me, as it doesn’t have any visible damage, but there was definitely something that happened to it since it was sold for $2200. It didn’t seem to have any problems with it, other than OS issues. I upgraded from 2.5 to 3.1 soon after receiving it.
Now there are two problems that I’ve been encountering that make me worry that I might have a serious (hardware) problem on my hands. One is that there is sound of the last note played going very softly even when all OSCs are turned to off. This doesn’t happen all of the time, but it does sometimes. I can’t pin down the exact cause, but it is possible that the OS isn’t installed correctly. I’ve installed v3.1 and the presets, but something went wrong as I can view the presets, but they don’t have any bearing on which sound comes out. It’s always the init. parameter patch, which doesn’t change when I try to go through patches.
That’s not a huge deal for me right now, as I don’t need to work from the presets - I’m just waiting for v3.2 so I can interface with the Mac Voyager utility.
However, I do have a larger problem, one that I can’t imagine is anything but hardware. I’ve had the synth turn itself off and start over quite a few times over the past few weeks. One of those times, the screen went completely dark (contrast got reset) and everything on the PANEL view was written in gibberish. That’s when the presets stopped working and I subsequently reinstalled the OS - upgrading to v.3.1 from 2.5. I’ve had a few more of these involuntary restarts, although they’ve been less catastrophic since then, more like a normal power cycling where the sound parameters that I had up remained unchanged. I’ve realized that the cause has something to do with the panel with the pitch and mod wheels. The first, biggest restart happened when I was touching the pitch wheel. Lately, it’s been happening when I come in contact with the screws just below the wheels. Usually there is a static electricity spark - when there is no spark, there is no problem. Last night, I even observed the LFO light go from the 1 hZ it was set to to a wildly fast speed before slowing down over the course of a few seconds back to normal.
Here’s the real question I’m facing. Is this unit a dog? I’ve just sent all this info to Moog and asked whether it has been sent back for major work in the past. I still have 10 days left on a 45-day return from the store. Should I cut all ties with this unit while I still can? Or is this a common problem due to a loose connection/bad power? I’d love to keep my great deal, but not if I am going to be living with a lemon!
