Hi - a while back I asked about a Voyager/XV351/MS20 combo and if it would work. We decided that it should be okay as “only the main CV in that had the exponential behaviour and that the other ins were normal”.
Anyway, I FINALLY got a stand and things rigged up properly so I could have a play last night. Works totally as expected which is great..
There is one issue regarding temperature. Basically, because of the Linear/Exponential mix, there will be a bit of ‘drift’ with temperature. If you only plan to do modulation stuff which is not really ‘tuning important’, you should not every notice this drift. Even if tuning is import I think it will just become unstable with temperature change so once warmed up, again not noticeable..
I don’t really understand all of this so here is a reply from Colin Fraser (P3 Sequencer designer) but in summary, it does work..
I think there may also be temperature compensation issues this way too.
The typical converter circuit used in an analogue synth to convert from a linear voltage to an exponential current relies on certain properties of a transistor which are temperature sensitive. I’ll not bore you with the formula…
Normally this factor would be cancelled out, either by using a resistor with the opposite temperature sensitivity to the transistor, or by heating the transistor to a fixed higher-than-ambient temperature. But in non-critical applications, cheapskate synth builders will leave temperature compensation out.
In the MS20, there is an exponential converter circuit used for modulation of the VCOs, but a linear input to the converter circuit is used to control frequency, from the hz/v keyboard circuit. The linear input is not sensitive to temperature. The expo input is, but this will only cause a scaling error in your modulation signals, so you wouldn’t normally notice.
If you use the modulation input to exponential frequency control, you will have to rescale as ambient temperature changes.
