What’s the best way to connect my Voyager to my computer to use the Voyager Editor program? I’ve seen the Turtle Beach & Hosa MIDI to USB connector cables, is that the standard way? My computer has Firewire (4 pin nonpowered variety); is there a Firewire option?
You can probably tell that I know almost nothing about MIDI; thanks in advance for any advice on this topic.
I use the M-Audio Midisport 2x2. You’ll need two midi cables as well; for an In and an Out. I think the Midisport is $50-60. You don’t use the Firewire port. The Midisport uses USB. Now there might be other interfaces that use Firewire.
