Hi all,
I’ll post a group note here to hopefully cover all points to date.
Is it normal, that you have to fill in the registeration data on this version? I think I did not had to do so on the other versions that came after I registered.
For Mac version it is the same code and you ini file should still work. But because of some compiler choice changes here at SoundTower the PC version will need to have new codes. Moog will email those with PC versions shortly to get you up and running. If you cannot wait please email moog [at] soundtower [dot] com with your original name used and email for the info .
The ability to load Moog Voyager sounds as single preset or panel dump file would be very helpful.
If you are asking for this from sysex only then no problem; we will implement this. Please be patient for update.
Sound available at the Moogspace or the Yahoo group come in this format. And one still needs a seperate sysex sender software to load these files into the Voyager.
This is doable if you click on Help in main menu and select: “Moog Voyager OS Update” You will open a dialogue box that will let you choose any .syx file to load if you have it on your HDD. Be it an OS update or just a patch. Just a courtesy to help avoid having to load up Midi-Ox (very fine product btw) or what not.
only some remarks on the demo version (Classic-Surface):
- switching a (e.g. 6-state) switch to its most left position displays a ‘1’ inside its center
- switching it one position to the right displays a ‘0’
- the most right position shows a ‘4’
- switching one position backwards (to the left) delivers a ‘5’
… a little bit confusing at the moment.
Turning a pot to its most left position rarely shows a ‘0’ at its center, but mostly a ‘4’, or ‘3’, while the ‘Par No.’ top line always displays exactly ‘0’.
You are correct; thank you, I’ve sent this on to programming. This slight oversight will be dealt with quickly.
Very, very nice design of the full scaleable ‘Classic-Surface’, really. Thank you a lot!
Thank you!!
so, do i have to buy it again?
Nothing about upgrades at the moog website, ok, i have a look at soundtower now, but why isn’t something mentioned here?
No you do not. Moog is incredibly busy and I am sure they will have all pertinent information available soon. Our site will pretty much just direct you back here. If you have a technical question regarding the software then: moog [at] soundtower [dot] com is the way to go.
is there an update for vers. 2.0.2 PC users available?
V3.0 is the one to use to update from 2.0.2 version for PC. To do so just double click on the setup exe and it will do the replacement.
Thanks ever so much for you input! Don’t be shy now; we need to know what you think.
Cheers
Derek
www.soundtwer.com
