I’d like to ask the community whether you may have a solution or suggestion to the following problem.
After some days of not touching my RME Voyager I cannot play different notes anymore. With two different Midi keyboards the symptom is the same. By pressing a key on the keyboard just one (Same) note can be activated, regardless which key is pressend . The panel function is working (eg filter poties, pitch or mod wheels ok).
Am I just brainwashed and unable to find a proper function in the operating software or could it be a real defect? Any help or recommendation will be very much appreciated.
Thanks and
Thanks for the reply. Following comments/answers I have at the moment:
DAW: No, I’m not using DAW herewith
direct plug in: Yes, direct connection from Midi-keyboard to RME, and no, via midi through port from Slim Phatty above
ruled out midi cable: Yes, midi cable works fine, e.g. with phatty and memotron which are in the same rack
Again, both slim phatty and memotron are working fine with the midi keyboard, only the RME shows strange behaviour. Yesterday I’ve got a hint from my local dealer (Hieber Lindberg, Munich) to do a software update.
RME now back from repairing. Defektive Oscillator board changed. At that opportynity slew rate modification implemented. Everything works fine again - no, much better! This modification is really fantastic. Sound is extremely good now. I did not expected such an improvement. Great job by Rudi from Lintronics! Thank you very much Rudi!
And also many thanks to Stefan (EMC) and Martin (Hieber Lindberg) for their competent and smooth support herewith.
